The old Big Cam Cummins engines built from about 1977 until the late 80's used a low pressure sender that was strong enough that it didn't need a relay. With electronic engines, the ECM reads the pressure sender and turns on the light and Buzzer. The buzzer came on at around 6 psi and it was simple to wire. I would think they sending units are still available because there are still a lot of mechanical engines in service. Kysor even made a shutdown unit that read oil pressure and water temp. They were popular with fleet and lease trucks. Kysor called it an alarmstat and they are still available.
