remove pushbutton assembly(selenoid) from top of starter. Clean contact button on top of starter. May be easier to remove starter from vehicle due to location of screws holding starter button assembly. If the button is worn or the contact inside the button assembly is worn you may be best to replace the button assembly. Over time the button or contact can get corroded from use or arcing. Local parts store family owned not major chain made up 00 gauge cables for me.
