| | | Forums66 Topics128,282 Posts1,058,497 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | 1.Get any correct new pump from any store. 2.Replace both filters as stated. 3.Be sure it's fuel hose you are using.
Then try starting and see how it runs with the carb not rebuilt. You can set a can right next to the front wheel, passenger side, on the ground, with a shorter hose, if you want to.
The carb is a good carb in my opinion. Everybody has their stories about which is better. I have had good luck with Rochester. I would have to put a four barrel on it if it was mine....and headers... with duals...good way to get a few horses and tones without breaking into the motor or the bank.
I think you said this 5 gal can was clean. Did motor smoke or backfire thru carb? Assume you are using brand new gas from a gas station.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | |
Entire Thread
1965 283 with manual choke, need help starting please
| p5861 | 09/24/2015 2:50 AM |
Re: 1965 283 with manual choke, need help starting please
| Builder | 09/24/2015 5:04 AM |
| p5861 | 09/24/2015 6:39 AM |
| p5861 | 09/24/2015 6:56 AM |
| Uncle Brad | 09/24/2015 9:22 AM |
| p5861 | 09/24/2015 3:58 PM |
| Uncle Brad | 09/24/2015 9:21 PM |
| RodTheWrench | 09/24/2015 4:40 PM |
| Uncle Brad | 09/24/2015 4:48 PM |
| p5861 | 09/24/2015 7:08 PM |
| bartamos | 09/24/2015 10:31 PM |
| p5861 | 09/25/2015 12:12 AM |
| p5861 | 09/25/2015 12:28 AM |
| bartamos | 09/25/2015 3:17 AM |
| p5861 | 09/25/2015 7:22 AM |
| Builder | 09/25/2015 5:07 PM |
| bartamos | 09/25/2015 6:03 PM |
| Uncle Brad | 09/25/2015 9:52 PM |
| bartamos | 09/25/2015 10:20 PM |
| p5861 | 09/26/2015 1:02 AM |
| p5861 | 09/26/2015 1:07 AM |
| bartamos | 09/26/2015 1:47 AM |
| p5861 | 09/26/2015 2:24 AM |
| bartamos | 09/26/2015 2:34 AM |
| brokenhead | 09/26/2015 5:42 AM |
| carbking | 09/26/2015 2:02 PM |
| p5861 | 09/26/2015 5:17 PM |
| carbking | 09/26/2015 6:20 PM |
| p5861 | 09/26/2015 7:06 PM |
| carbking | 09/26/2015 7:29 PM |
| bartamos | 09/26/2015 9:23 PM |
| Rsqwhite | 09/26/2015 10:06 PM |
| Rsqwhite | 09/26/2015 10:11 PM |
| carbking | 09/26/2015 10:43 PM |
| bartamos | 09/26/2015 11:24 PM |
| carbking | 09/26/2015 11:34 PM |
| bartamos | 09/26/2015 11:38 PM |
| p5861 | 09/27/2015 7:10 AM |
| Rsqwhite | 09/27/2015 2:35 PM |
| bartamos | 09/27/2015 7:47 AM |
| p5861 | 09/29/2015 5:50 PM |
| bartamos | 09/29/2015 8:12 PM |
| p5861 | 09/30/2015 3:37 AM |
| bartamos | 09/30/2015 4:02 AM |
| p5861 | 09/30/2015 4:37 AM |
| bartamos | 09/30/2015 5:21 AM |
| carbking | 09/30/2015 6:49 PM |
| 52Carl | 10/01/2015 1:39 AM |
| p5861 | 10/01/2015 7:26 AM |
| bartamos | 10/01/2015 8:13 AM |
| 55shaker | 10/01/2015 2:49 PM |
| p5861 | 10/03/2015 8:50 PM |
| p5861 | 10/07/2015 7:45 AM |
| Volfandt | 10/08/2015 1:35 AM |
| p5861 | 10/11/2015 6:47 AM |
| carbking | 10/11/2015 1:16 PM | |
