| | | Forums66 Topics128,282 Posts1,058,497 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2007 Posts: 71 Shop Shark | | Shop Shark Joined: Apr 2007 Posts: 71 | ok so here is the next report today i attempted another start, here are the observations
> with filters removed it took about two 30 second cranks to see fuel flow from the carb inlet, with one in-line filter installed just before the carb i got the same result. fuel looked like healthy "garden hose pulsing"
>i connected the line back to the carb inlet, manually moved the choke to about 1/8' gap, pumped 3-5 times and cranked- motor did not start
>i sprayed starting fluid into the carb, reset choke to about 1/8" gap and cranked.... it attempted to start but quit
>i repeated above with starting fluid 3 more times before it finally stayed running
>i let it run for about 30 minutes, the choke is still gaped at only about 1/8" , the minute i try to open the choak even slightly it stalls, i could rev the motor by repeatedly pumping the pedal but as soon as i let up on the pedal it stalls
>after it stalls its been 50/50 that i can just turn the key to start it, half the time i need to use the starting fluid again.
NOTE-all the while the choke is set to about 3/16" gap which seems to be the sweet spot
the carb is a rochester 2bbl, it was rebuilt a while back, minimally used and than sat for another two years. i dont know a thing about carbs or choking techniques so this is a learning experience
i purchased the truck a while back and life got in the way so to be honest i never got to really enjoy the truck running well, just fighting to get it started and moving it from storage spot to storage spot, hopefully that will change
thanks for sticking with me on the thread | | | |
Entire Thread
1965 283 with manual choke, need help starting please
| p5861 | 09/24/2015 2:50 AM |
Re: 1965 283 with manual choke, need help starting please
| Builder | 09/24/2015 5:04 AM |
| p5861 | 09/24/2015 6:39 AM |
| p5861 | 09/24/2015 6:56 AM |
| Uncle Brad | 09/24/2015 9:22 AM |
| p5861 | 09/24/2015 3:58 PM |
| Uncle Brad | 09/24/2015 9:21 PM |
| RodTheWrench | 09/24/2015 4:40 PM |
| Uncle Brad | 09/24/2015 4:48 PM |
| p5861 | 09/24/2015 7:08 PM |
| bartamos | 09/24/2015 10:31 PM |
| p5861 | 09/25/2015 12:12 AM |
| p5861 | 09/25/2015 12:28 AM |
| bartamos | 09/25/2015 3:17 AM |
| p5861 | 09/25/2015 7:22 AM |
| Builder | 09/25/2015 5:07 PM |
| bartamos | 09/25/2015 6:03 PM |
| Uncle Brad | 09/25/2015 9:52 PM |
| bartamos | 09/25/2015 10:20 PM |
| p5861 | 09/26/2015 1:02 AM |
| p5861 | 09/26/2015 1:07 AM |
| bartamos | 09/26/2015 1:47 AM |
| p5861 | 09/26/2015 2:24 AM |
| bartamos | 09/26/2015 2:34 AM |
| brokenhead | 09/26/2015 5:42 AM |
| carbking | 09/26/2015 2:02 PM |
| p5861 | 09/26/2015 5:17 PM |
| carbking | 09/26/2015 6:20 PM |
| p5861 | 09/26/2015 7:06 PM |
| carbking | 09/26/2015 7:29 PM |
| bartamos | 09/26/2015 9:23 PM |
| Rsqwhite | 09/26/2015 10:06 PM |
| Rsqwhite | 09/26/2015 10:11 PM |
| carbking | 09/26/2015 10:43 PM |
| bartamos | 09/26/2015 11:24 PM |
| carbking | 09/26/2015 11:34 PM |
| bartamos | 09/26/2015 11:38 PM |
| p5861 | 09/27/2015 7:10 AM |
| Rsqwhite | 09/27/2015 2:35 PM |
| bartamos | 09/27/2015 7:47 AM |
| p5861 | 09/29/2015 5:50 PM |
| bartamos | 09/29/2015 8:12 PM |
| p5861 | 09/30/2015 3:37 AM |
| bartamos | 09/30/2015 4:02 AM |
| p5861 | 09/30/2015 4:37 AM |
| bartamos | 09/30/2015 5:21 AM |
| carbking | 09/30/2015 6:49 PM |
| 52Carl | 10/01/2015 1:39 AM |
| p5861 | 10/01/2015 7:26 AM |
| bartamos | 10/01/2015 8:13 AM |
| 55shaker | 10/01/2015 2:49 PM |
| p5861 | 10/03/2015 8:50 PM |
| p5861 | 10/07/2015 7:45 AM |
| Volfandt | 10/08/2015 1:35 AM |
| p5861 | 10/11/2015 6:47 AM |
| carbking | 10/11/2015 1:16 PM | |
