| | | Forums66 Topics128,282 Posts1,058,497 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2007 Posts: 71 Shop Shark | | Shop Shark Joined: Apr 2007 Posts: 71 | 1)no i did not replace the fuel pump yet
2)with the carb inlet disconnected when cranking i do notice what appears to my untrained eye a reasonably healthy flow of fuel BUT as outlined earlier i was only able to achieve that after manually injecting/priming fuel into the line from the tank end. (there is one filter at the carb inlet though)
i did wait and repeat the sequence and got the same result, i will try again tomorrow and see if the fuel still flows after an overnight rest.
thanks | | | |
Entire Thread
1965 283 with manual choke, need help starting please
| p5861 | 09/24/2015 2:50 AM |
Re: 1965 283 with manual choke, need help starting please
| Builder | 09/24/2015 5:04 AM |
| p5861 | 09/24/2015 6:39 AM |
| p5861 | 09/24/2015 6:56 AM |
| Uncle Brad | 09/24/2015 9:22 AM |
| p5861 | 09/24/2015 3:58 PM |
| Uncle Brad | 09/24/2015 9:21 PM |
| RodTheWrench | 09/24/2015 4:40 PM |
| Uncle Brad | 09/24/2015 4:48 PM |
| p5861 | 09/24/2015 7:08 PM |
| bartamos | 09/24/2015 10:31 PM |
| p5861 | 09/25/2015 12:12 AM |
| p5861 | 09/25/2015 12:28 AM |
| bartamos | 09/25/2015 3:17 AM |
| p5861 | 09/25/2015 7:22 AM |
| Builder | 09/25/2015 5:07 PM |
| bartamos | 09/25/2015 6:03 PM |
| Uncle Brad | 09/25/2015 9:52 PM |
| bartamos | 09/25/2015 10:20 PM |
| p5861 | 09/26/2015 1:02 AM |
| p5861 | 09/26/2015 1:07 AM |
| bartamos | 09/26/2015 1:47 AM |
| p5861 | 09/26/2015 2:24 AM |
| bartamos | 09/26/2015 2:34 AM |
| brokenhead | 09/26/2015 5:42 AM |
| carbking | 09/26/2015 2:02 PM |
| p5861 | 09/26/2015 5:17 PM |
| carbking | 09/26/2015 6:20 PM |
| p5861 | 09/26/2015 7:06 PM |
| carbking | 09/26/2015 7:29 PM |
| bartamos | 09/26/2015 9:23 PM |
| Rsqwhite | 09/26/2015 10:06 PM |
| Rsqwhite | 09/26/2015 10:11 PM |
| carbking | 09/26/2015 10:43 PM |
| bartamos | 09/26/2015 11:24 PM |
| carbking | 09/26/2015 11:34 PM |
| bartamos | 09/26/2015 11:38 PM |
| p5861 | 09/27/2015 7:10 AM |
| Rsqwhite | 09/27/2015 2:35 PM |
| bartamos | 09/27/2015 7:47 AM |
| p5861 | 09/29/2015 5:50 PM |
| bartamos | 09/29/2015 8:12 PM |
| p5861 | 09/30/2015 3:37 AM |
| bartamos | 09/30/2015 4:02 AM |
| p5861 | 09/30/2015 4:37 AM |
| bartamos | 09/30/2015 5:21 AM |
| carbking | 09/30/2015 6:49 PM |
| 52Carl | 10/01/2015 1:39 AM |
| p5861 | 10/01/2015 7:26 AM |
| bartamos | 10/01/2015 8:13 AM |
| 55shaker | 10/01/2015 2:49 PM |
| p5861 | 10/03/2015 8:50 PM |
| p5861 | 10/07/2015 7:45 AM |
| Volfandt | 10/08/2015 1:35 AM |
| p5861 | 10/11/2015 6:47 AM |
| carbking | 10/11/2015 1:16 PM | |
