another option
Weld a nut on a small flat plate
Drill two holes for spot weld adjacent
Spot Weld from front. You can also just thread a 1/4 thick bar stock and Flat Hd screw/rivet in place.... Same idea, no welding.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn |
