No, the gauge on the gun should be around 40-50 I believe to get you in the ballpark. I tried setting it at 10 psi, and the paint came out like a sprinkler smile Once the 40-50 psi goes through the gun (as read on your gauge), the air psi comming out the tip is about 10.
'53 Chevy truck 1/2 ton
