I have a chip on my hood up by the top left corner...It's about the size of a half dollar so not that small. I need to blend it the best I can and need some advice on how to approach this.. I have cleaned and lightly sanded the area. I'm guessing I'll need to apply several coats to bring it up to the level of the good paint. It will likely take several more applications. Yes, it still had primer in good condition.
My first attempt with just a tiny brush looks OK but far from perfect which likely I can't get w/o a spray. Will a coat of clear as a final make it blend in better ?
Mark
1949 Chevy 1/2-Ton
Lucielle
Name after my Uncle's Wife..
More pictures on Photobucket
If there are no dogs in heaven, then when I die I want to go where they went. ... Will Rogers
