7 members (Tronman, Dennys28, 39Master85, dt235sd, carbking, kades51, 1 invisible),
58
Mod | | | Forums66 Topics128,180 Posts1,057,149 Members48,464 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2012 Posts: 543 Shop Shark | | Shop Shark Joined: Nov 2012 Posts: 543 | I have a chip on my hood up by the top left corner...It's about the size of a half dollar so not that small. I need to blend it the best I can and need some advice on how to approach this.. I have cleaned and lightly sanded the area. I'm guessing I'll need to apply several coats to bring it up to the level of the good paint. It will likely take several more applications. Yes, it still had primer in good condition.
My first attempt with just a tiny brush looks OK but far from perfect which likely I can't get w/o a spray. Will a coat of clear as a final make it blend in better ? | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | Do you have the chip? How long has it been there? Is bare metal exposed? What kind of paint and how many layers?
| | | | | Joined: Nov 2012 Posts: 543 Shop Shark | | Shop Shark Joined: Nov 2012 Posts: 543 | No...don't have the chip.. It's been there about a year. No bare metal...only primer. Some kind of enamel. So far about five layers... It is looking like it will turn out OK..
Likely I should have used a tiny spray bottle but it's done now. | | |
