Steve,Sure LOOKS like the '56 6400 frame that you trailered from Iowa,from the looks of the rear cross-member area. That one HAD 6-bolt RH5's. Your rear hubs,(5-hole wheels),SHOULD be 10-bolt. Rims should match,since you don't want the sidewalls of the tires to rub. "We" have about 8 good 3-piece rims,5-hole,10-bolt), still available,if you need any. What happened to your springs??
Mo' Tater
