UPDATE: This summer I was able to swap out the 6 volt system for a 12 volt system. Everything seems to be working but could definitely use a new wiring harness. I also, swapped out the leaky master cylinder. The master cylinder on the truck was for a 47-52 1 ton. So, I just bought one of those instead of re plumbing the lines for the correct 54. I ordered tires but ran out of time so, they will have to wait until spring when I get back to Michigan.
1950 GMC 100
1954 GMC 470
1954 Chevy 3100 Hydramatic
More pix on Flickr
1957 Ford 850 Tractor (video)
