I used this process..
-Bare metal
-Rust repair/metal work
-DP Epoxy primer
-All body work
-Evercoat Slick Sand ( cheaper than K38. A sprayable body filler almost)
-Block with 80 touch up body work
-PPG K38 Block with 220 dry fill minor imperfections
-PPG K38 Block with 320 wet
-Wet sand with 500
-DP Epoxy reduced with DT870
-PPG DBC base coat
-PPG 2002 clear with DFX11 hardner and reduced with DT 885
See the photo's in the links below.
Randy Domeck
Indianapolis Fabrications
[email protected]
Indianapolis, In. 46254
317-258-0039
