I have my 49 done from the ground up and it wants to pull to the right, I have had it aligned by two shops and it is right on the specs but still pulls to the right. I have the stock suspension with upgraded shocks, the truck is lowered about 2" all around, I am running 235/70\15 tires on 8" rims 35 psi. What could cause this to pull to the right or what can I try to eliminate it. Also I swapped the front tires L to R and it made no difference.....any ideas are welcome
THANKS
BILL
