Hi Andy,
If they are rusted pretty bad, soak them down with your favorite penatrating oil and let them sit for a day or two. If they are really bad, I have just kept them damp with the oil. Some of them took a couple of weeks. Every time I went by the truck, I would squirt some oil on them. I have found that with some of the old bolts, if you tighten them just a little, and then loosen, they will come out. If you break them off, then use a drill to drill into the old bolt shank and a screw extractor tapped into the old shank and turn it out. Once it breaks loose it will come out pretty easy. Good Luck.
Hope this helps.
Mark
1951 Chevy 3100
Some days you get the bear. Some days the bear gets you.
