| | | Forums66 Topics128,113 Posts1,056,613 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy lefty1, there is a bolt retaining a plate which fits in a slot in the pedal pivot shaft. If you remove the bolt you should be able to remove the plate and tap the pivot shaft out of the master cylinder and the pedal releasing the pedal from the master cylinder, hope that helps. | | |
