4 members (Gdads51, Otto Skorzeny, 2 invisible),
113
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,052 Posts1,055,743 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2002 Posts: 153 Shop Shark | | Shop Shark Joined: Sep 2002 Posts: 153 | I have a 1946 with a 1956 235. Stock engine except Edmunds dual exhaust and HEI distributor. I installed Dyna Mat on the firewall and floor. I also installed the insulation pad on the inside of the firewall and a floor mat. But the cab still gets hotter than expected.
Do the pans between the frame and oil pan help pull airflow through the radiator and continue under the cab? Would I be better off without the pans and get additional airflow from the bottom? 1946 Chevy Half Ton ('56 235, '86 T5, '79 Camaro Z28 rear end, working on the '85 Jaguar XJ6 IFS) 1976 Margay Panther X, MC91B | | |
