Matties,
Post a Parts Wanted ad in the Swap Meet (19511952-1959, I think). There seems to be many people who remove/change the front-steering parts to change the front suspension/steering.
The main problem with many used spindles/knuckles (as you most likely know) is the journals for the king-pin bushings get "wallowed out". Ask sellers to carefully inspect those journals.
Last edited by tclederman; 05/24/2015 11:13 PM. Reason: corrected years - see post below
