| | | Forums66 Topics128,100 Posts1,056,515 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | You think you got it bad. My ride has 15 candlepower headlights. You can hardly read a newspaper at night six inches from them. Seriously, it all about watts. P(watts)= I(amps) X E(voltage). Your voltage is constant, so the only thing you can change is amps to get more watts(brighter lights). Have you thought about a relay. The run of the mill relay costs less than five bucks. It's good for 30 amps. A few feet of heavy wire #10 inside the engine deck with the feed wire from your light switch to energize the relay and you got it. Good luck.
