| | | Forums66 Topics128,121 Posts1,056,328 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,808 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,808 | There's a simple, quick fix that I learned while working in a radiator shop. Buy a flex hose that fits the bigger diameter, such as the 1 1/2" thermostat housing, and cut a short section of 1 1/4" hose to slip over the upper nipple on the radiator. Install this piece on the radiator nipple WITHOUT SEALER OR ADHESIVE and slip the larger hose over it. Clamp it snugly with a worm-drive hose clamp, and it will be secure and leakproof. Do the same thing with the lower hose, adapting the larger diameter hose to the smaller radiator nipple with a reducer sleeve. This has worked for me on race engines with 20+ PSI radiator caps. Jerry
