7 members (55shaker, crenwelge, Gray_Ghost, JW51, Cosmo, Lostbuthaulinass, Hugh63c10),
226
2
Mod | | | Forums66 Topics128,108 Posts1,056,237 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2001 Posts: 46 Member | | Member Joined: May 2001 Posts: 46 | LOL!!! Freedo, May be more troble than its worth.Seam sealer in the drip is probably driedout, cracked and leaking.Maybe more rust in between the double walls and tough to get to and stop. Here's what you do, Take a trip down to my place and pick up my old cab (I'll give it to you for hauling it off,I need the space.)Repair the floorboards and rockers(cab corners... while your on a roll).Also May need to install a 700R4 cause had an automatic. You'll be roll'n in no time.  | | |
