1 members (texczech),
51
2
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | On a good clean engine you can use the "finger" check for compression. Pull the #1 plug. Stick a finger into the hole. Turn the engine. When the finger is pushed out, that is compression. The timing mark will come around 2 times for each compression stroke. 1 time with the exhaust valve open, and 1 time with both valves closed. Set the points to just open and it should start. A common screwdriver can be used to index the oil pump. The distributor will rotate some as the gear meets the cam. So set the oil pump a little ahead and the distributor should go in easy.
Steve H
