Register Log In
The Stovebolt Site Forums The Shop Area Engine Shop Checking valve clearance while running?
Forums Active Threads
Remembering
9 - 11
Remembering 9-11 Share your thoughts
images
remembrances
5 members (KCMongo, TUTS 59, Gray_Ghost, IHPWR, 49choptop), 106 guests, and 2 robots.
Topics128,034
Posts1,055,540
Members48,425
Re: Checking valve clearance while running?
chevyute #1092559 03/20/2015 5:03 PM
Jarvisburg, NC, USA
tclederman Offline
tclederman
Offline
Jarvisburg, NC, USA
http://www.autozone.com/clamps-and-...2-blades-go-no-go-feeler-gauge/1928_0_0/
http://www.amazon.com/Lisle-68150-Go-No-Go-Feeler-Gauge/dp/B000HI9E7U
http://buy1.snapon.com/catalog/parts/pro_det.asp?Item_id=638270&group_id=677428
Tim
1954Advance-Design.com
1954 3106 Carryall Suburban
1954 3104 5-window pickup w/Hydra-Matic
The 216 and early 235 engines are not "splash oilers" -- this is a splash oiler.
Copy Link to Clipboard
Entire Thread
Subject Posted By Posted
Checking valve clearance while running? chevyute 03/19/2015 3:44 AM
Re: Checking valve clearance while running? Joe H 03/19/2015 3:50 AM
Re: Checking valve clearance while running? Achipmunk 03/19/2015 4:09 AM
Re: Checking valve clearance while running? tclederman 03/19/2015 4:12 AM
Re: Checking valve clearance while running? crenwelge 03/19/2015 5:08 AM
Re: Checking valve clearance while running? Denny Graham 03/19/2015 1:12 PM
Re: Checking valve clearance while running? tclederman 03/19/2015 1:53 PM
Re: Checking valve clearance while running? Dave Parque 03/19/2015 4:00 PM
Re: Checking valve clearance while running? Hotrod Lincoln 03/19/2015 4:38 PM
Re: Checking valve clearance while running? pfarber 03/19/2015 5:00 PM
Re: Checking valve clearance while running? Red 49 Truck 03/19/2015 6:58 PM
Re: Checking valve clearance while running? Hotrod Lincoln 03/19/2015 7:03 PM
Re: Checking valve clearance while running? Steve_H 03/19/2015 7:28 PM
Re: Checking valve clearance while running? crenwelge 03/20/2015 6:50 AM
Re: Checking valve clearance while running? Hotrod Lincoln 03/20/2015 3:02 PM
Re: Checking valve clearance while running? tclederman 03/20/2015 5:03 PM
Re: Checking valve clearance while running? pfarber 03/20/2015 5:40 PM
Re: Checking valve clearance while running? Uncle Brad 03/20/2015 7:51 PM
Re: Checking valve clearance while running? Joe H 03/21/2015 12:06 AM
Re: Checking valve clearance while running? crenwelge 03/21/2015 12:36 AM
Re: Checking valve clearance while running? Roy Rodgers 03/21/2015 2:56 PM
Re: Checking valve clearance while running? rickmg 03/21/2015 3:23 PM
Re: Checking valve clearance while running? J M 03/22/2015 5:53 AM
Re: Checking valve clearance while running? coilover 03/22/2015 11:17 AM
Re: Checking valve clearance while running? Steve_H 03/24/2015 10:03 PM
Re: Checking valve clearance while running? tclederman 03/24/2015 10:46 PM
Re: Checking valve clearance while running? 52Carl 03/25/2015 3:35 AM
Re: Checking valve clearance while running? Joe H 03/25/2015 4:00 PM
Re: Checking valve clearance while running? Pre '68 Dave 03/25/2015 4:20 PM
Re: Checking valve clearance while running? crenwelge 03/26/2015 2:49 AM
Re: Checking valve clearance while running? Hotrod Lincoln 03/26/2015 3:55 AM
Switch to Flat Mode
Show Likes
View Profile
Private Message
Website
Follow User
Forum Posts
Forum Rules · Mark All Read Contact Us · Forum Help · The Stovebolt Site
