7 members (55shaker, 1955 1 Series, Bill Hanlon, Oswald, Greg_H, Ponchogl, Shade Baby),
140
2
Mod | | | Forums66 Topics128,261 Posts1,058,345 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,944 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,944 | The second paragraph is actually the procedure. The distributor housing doesn't have to be removed- - -just loosen the clamp that holds the housing to the vacuum advance and turn the housing about 180 degrees. Then you'll have to re-set the timing and plug wire routing to make a different cap tower align with the #1 plug. The pointer/ball alignment happens twice, once when #1 is on compression, and again one turn of the crankshaft later when #6 is in firing position, so it's an absolute necessity to know which cylinder is on the compression stroke. If the rotor is pointed to the #1 plug wire right now, just turn the distributor housing half a turn and rearrange the plug wires accordingly. Jerry
