Just put a T in the line to the booster. You'll need full intake vacuum and a big enough hose to get a good gulp of the air in the crankcase every time the PCV cycles open. Your booster should have a 1-way check valve in it, so you're not going to lose vacuum to the booster as the PCV cycles.
