2 members (Guitplayer, 1 invisible),
174
3
Mod | | | Forums66 Topics128,196 Posts1,057,395 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,885 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,885 | The resistance wire was really a smart idea- - - -it spread the voltage drop needed to keep the points from burning out over several feet instead of concentrating it in one place and developing so much heat that the resistor needed a ceramic insulator. I've never seen a resistance wire burn out- - - -and I've seen bunches of ballast resistors fail.
Never, EVER try to power a HEI ignition with a resistor wire! That 10 gauge wire from the ignition switch to the coil is there for a reason! Jerry
