| Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,852 | Don't bother pulling the pan- - - -the plug goes into a blind hole. Its only function is to stop the oil pump output from getting to the main oil gallery, and diverting it to the filter first. Heat the block before you try to drive the plug in- - - -it's a TIGHT fit. Jerry
