I have an electronic sender on the trans and electronic speedo.
I have a 2 speed rear end.
For a cable speedo it is no problem... Just install a speedo "transmission" in line to the speedometer cable and you're good to go.
For the electronic?
Does anyone make a box that accepts a "low range" input (from the 2 speed shift switch) that will change the speedo ratio?
Other solutions?
