| | | Forums66 Topics128,094 Posts1,056,064 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#10856 06/03/2005 3:58 AM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | If your tranny has reverse to the left and down, it is the SM420. I actually prefer this to the later SM465, reverse to the right and down. The 420 has the advantage of being a faster shifting box, but both are durable boxes. For some general info go to http://www.novak-adapt.com/knowledge/knowledge_gateway.htm The bell housing will need machined to work, but it's minor. You could use a bell from a 68-72, but the starter and cluth mounts are different.
Fred 52 3600 69 C-10
