| Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,804 | Anyone with a couple of brain cells to rub together and some machine tools should be able to adapt a modern bypass stat to the 261 housing. Start with a thick chunk of aluminum and whittle away anything that doesn't look like what you want. The trick will be finding one of those thermostats that opens at less than 195 degrees. Jerry
