0 members (),
117
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,089 Posts1,056,141 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2011 Posts: 2,951 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 2,951 | Get under the truck and measure your current tranny and compare the length with the measurements in this T5 chart.
The Camaro and S10 T5s are 635.3 mm from the front of the case to the tail. Add the thickness of the adapter plate if you use one. | | |
