| | | Forums66 Topics128,135 Posts1,056,418 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,817 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,817 | 80 over isn't necessarily a bad thing, as long as the cylinders are smooth and not tapered. The more important concern is the piston-to-cylinder clearance. At one time we used long feeler gauge blades to check piston skirt clearance- - - -now it's more commonly done with a dial bore gauge in the cylinder and a micrometer to measure piston skirt diameter. Skirt clearance of .003" or less is a good thing- - - -very little piston slap, and the rings stay in good contact with the cylinder walls. If the piston fit is a little loose, it's possible to chuck the piston in a lathe and run a knurl on the skirt in 2 or 3 places. I've expanded pistons up to .003" or so by knurling and it really quiets one down that has noticeable piston slap before the rebuild.
Find a better-condition block if possible, but don't give up on the old one just because it's been bored, as long as it can be rehabbed otherwise. Jerry
