Originally Posted by 55 SHAKER
2004r's in grand national's and turbo regals turned 12's in the quarter. That takes some horsepower to do that.
Turning 12s in the quarter and having a transmission that will handle a load are completely different things. After re-reading what the op is planning to use the truck for (towing), the 200 is not a good choice. It simply is not load rated for that use. As I mentioned, the 200 was never used in a full size truck (some 4 cylinder 2wd S10s did use them). A 700 will live far better in a truck.
Since the ruck is no longer stock anyway, the driveshaft and transmission mounts are not really an issue.
Bill Burmeister
