I had a 69' Mustang once that did the same thing. To make a long story short, The rod that works the butterfly was worn and after all the "checking" the carb was just worn out. Replaced it and problem solved. Might be worth a check. Good luck. Steven
1949 Chevy 1/2-Ton ~ Red Truck
More pix on Photobucket
