1 members (78buckshot),
64
3
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2014 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2014 Posts: 52 | On my 61 Apache, the fuel tank is under the frame in the rear. I was told this tank was purchased from LMC. LMC only sells under the frame tanks for 1963-1966 C10's and not 1961. I believe that is why it does not have conventional straps holding it up. The sending unit that LMC sells along with this tank is also for a 1963-66 C10 not a 1961. Is there an ohms difference between a 1961 sending unit and a 1963-66? If so, that may be why my 1961 gauge does not work. Does anyone sell universal straps for a fuel tank? The ones on this tank are the strapping that is used on a wooden pallet and need to be cut off and cant be reused. Thanks | | |
