1 members (Hotrod Lincoln), 104 guests, and 2 robots.
Topics128,089
Posts1,056,004
Members48,430
#1060445 10/05/2014 9:25 PM
On my 61 Apache, the fuel tank is under the frame in the rear. I was told this tank was purchased from LMC. LMC only sells under the frame tanks for 1963-1966 C10's and not 1961. I believe that is why it does not have conventional straps holding it up. The sending unit that LMC sells along with this tank is also for a 1963-66 C10 not a 1961. Is there an ohms difference between a 1961 sending unit and a 1963-66? If so, that may be why my 1961 gauge does not work.
Does anyone sell universal straps for a fuel tank? The ones on this tank are the strapping that is used on a wooden pallet and need to be cut off and cant be reused.
1960-1966 C10 Gas Tank Sending Units and Gas Gages:
1960-1964 were 0-30 ohms, no debate
1965 and newer were 0-90 ohms, debatable....
I bought my gas tank and related parts from "Tanks, Inc." They sell universal tank straps: http://www.tanksinc.com/index.cfm/p...=277/category_id=62/mode=prod/prd277.htm
thumbs_up
