Motor mount/tranny mount....Never heard that kind of bang from throw out. Throw out usually sounds like a rattle can or bad radio station. Could be Ujoint also, I don't know the closed driveshaft system though. AD people will respond. A bad mount will hop more in lower gears due to torque load/gear ratio. Need to fix ASAP and not drive, can do some big damage. Are you sure it's from front area not rear end? A busted gear somewhere will sure bang! Tranny or rear. Settling down as shifting higher, leads me back to mounts or joints. 1st and Rev is a slight hint to a problem in tranny but they are both high load also. Let's see what the other folks have to say.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn |
