Does anybody know if or where a patch panel can be found for the pocket holes on the bed sides? Mine were welded shut by the PO in an attempt at smoothing the bed sides. I want the pockets open and was thinking that given all the beat up pocket holes I've seen, there might be an easier way. :confused:
Any suggestions? I tried cutting the back ones out with mixed results. I don't want to spend a ton on new bed sides unless that's the only remaining option.
Thanks!
