Check to see if a wire inside the distributor is shorting out as the vacuum advance moves. That was a common problem on the mid-1950's Fords, but they had a flexible wire between the distributor housing and the points that would develop broken strands. The wire from the coil to the distributor on yours might have a similar problem.
