I,ve got some kind of blockage in my tank. I took it out this Spring,to freshen it up a bit,before installing a new wiring harness. I connected all of the lines,(today),but still no fuel! I replaced the 5" cab-to-frame line,and blew-out the frame-to pump line. It seemed constricted,so I'm going to replace that line,as well. I was getting some fuel,at initial start-up,but then...not a drop. With 10 gallons in the tank,you'd think the gas would "siphon".but only got a drop or two,at the pump feed line. Same story at the tank outlet,(bottom of P.S. cab). That's what makes me believe I have some kind of blockage in the tank itself! I had the filler neck plugged,while in storage,but,there's got to be a reason! I'll let you know what I find out tomorrow. Probably in for another good laugh! B.T.W...For the short period of time the engine was running,I could sure tell the difference in the carb. already! I haven't even got it adjusted yet,and it IDLES!! One down,??? to go??
