| | | Forums66 Topics128,007 Posts1,055,279 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2002 Posts: 2,548 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,548 | 235 was standard in all 6000 series 2 ton 16000lb. gvw trucks, but yours being a special order 15000lb. 1 1/2 ton 6400, it could possibly have a 216 in it. best to get the engine casting number on the passenger side of the block, plus the eng. id number from the flat ledge, at the base of the dist. shaft, where it goes into the block. | | |
