Jerry will lead you to what you want to know.
Other extraneous information regarding timing marks:
The ball was the timing mark on the flywheel for that particular engine, in a particular year.
You might not have the original flywheel for your engine.
The timing mark/ball could have been TDC, before TDC, or after TDC, depending on year/engine.
