2 members (52Carl, Gdads51),
37
3
Mod | | | Forums66 Topics128,180 Posts1,057,161 Members48,464 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Can someone advise if a mechanical clutch/brake pedal assy will bolt up to a slave type assy under dash? 1960 GMC/Chevy 1/2T. AT present the clutch fork is on pass side with slave unit. Possibly will have newer bell housing/mechanical clutch in future. What are the suggestions. Will be much easier if the pedal brackets have same mounting on 60-66. I see pics of a Zbar, rods and bracket also.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | |
