7 members (mick53, elhippie64, papas52, stlcardinalsguy, KEVINSKI, Leo, 1 invisible), 63 guests, and 3 robots.
Topics128,180
Posts1,057,157
Members48,464
Sir Searchalot
Sir Searchalot
Can someone advise if a mechanical clutch/brake pedal assy will bolt up to a slave type assy under dash? 1960 GMC/Chevy 1/2T. AT present the clutch fork is on pass side with slave unit. Possibly will have newer bell housing/mechanical clutch in future. What are the suggestions. Will be much easier if the pedal brackets have same mounting on 60-66. I see pics of a Zbar, rods and bracket also.
Riding in the Passing Lane
I can't answer your Question but that hydraulic system works good. You just have to put kits in the cyls. every few years.
1972 Chevy c10 Cheyenne Super
Sir Searchalot
Sir Searchalot
I just thought if I put in a SBC or BBC that it would be easier. Not sure. I guess it does not matter what side the fork is on with hydraulic. Want to know my options, hopefully the mechanical assy bolts right up, sort of. Never had a hydraulic clutch.
