9 members (Tronman, TUTS 59, cmayna, Otto Skorzeny, UnclePaddy, Steelonsteel, Peggy M, 2 invisible),
78
3
Mod | | | Forums66 Topics128,042 Posts1,055,505 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Here is a shot of the surface that goes into the window rubber (groove). You need a different windshield gasket designed for this trim, the vendors including Steele Rubber all carry it. https://www.flickr.com/photos/advance-design_parts_co/9128808273/in/set-72157631868452754On the door trim you replace the painted with the stainless. It can be a bit of an exercise to replace. On the outside piece you need to bend/force it into place and it can bend in the wrong place if you are not careful. The inner one is easier I just leave all the screws loose as I go around starting them. I used originals so I am unsure how the reproductions fit? | | |
