I'm not quite sure how to describe this. I already reshaped the pan. The pickup tube is threaded into the side of the pump so when I push up on it it threads further into the pump but because of the shape of the tube it goes up at an angle. When it is in far enough for the bend in the tube to clear the pan bottom the screen is tipped up at an angle several inches above the bottom. I'm trying to say that it doesn't fit my pan. Where can I find a different tube/screen?Or maybe a deeper pan? Is there such a thing?---Jack
