Just to make sure I understand, you are reffring to the lock bolt holding in the pin the does not allow the axle to move in to remove the c-clips correct?
If yes, I'd suggest drilling out the remainder of the bolt enough to get the pin out. Then you can try to drill and retap the carrier. If that does not work, you'll need to find another carrier in the junkyard.
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
