| | | Forums66 Topics128,107 Posts1,056,225 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | This may be helpful: http://chevy.oldcarmanualproject.com/shop/1948_51truck/51ctsm0523.htmThe holes that go through the MC are for the mount bolts. Two of them just about the middle up and down. The bolts go through the frame and into a plate that is threaded. It is all straight forward when you get it clean and apart. Take the lines off, Remove the push rod, take put the two bolts and it will be in your hands.
Steve H
