In your original post you stated:
"Looking down the barrel when running, the fuel is dribbling out, you can hear each drip hit the throttle blade,..."
That is not your idle ciruit acting up. The idle circuit is not visible to the eye when idling, it is below the throttleblades. What you are seeing is fuel coming from the boosters, float being too high? would be a typical cause.
