| | | Forums66 Topics128,006 Posts1,055,272 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | It depends if you have the front sheetmetal on the truck. If you don't have it on the job of installing the motor and transmission together is not to tough. If the truck is assembled putting them in together is difficult. You should be able to leave the transmission installed and mate the motor to it. Make sure that you use a clutch alignment shaft. Many will take the transmission out, install the engine and then install the transmission. It is all about your comfort level doing the job. | | |
