If the wires were hooked on the back of the fuel gauge incorrectly will that ruin it? I installed a new sending unit. I have one wire hooked to the back of the gauge frome the ignition switch and the other terminal on the gauge has the wire from the sending unit connected to it, the tank is full but does not register on the gauge. Where did I go wrong?
